Marking Rail Front Edge|Forum|WOOD DESIGNER
March 19, 2020 - 2:30 pm
With single panel fittings you can add this with your top rail structure sub-method.
See inside your cabinet the sub-method Material > Structure TOP RAIL 2
Cheers, Alexandre
Blake Simpson
Forum Posts: 104
March 17, 2020 - 9:49 pm
I am trying to add a fitting link (three dots) that will identify the front edge of the front rail to enable the factory to clash the correct edge. More of an issue with fixed drilling positions when using cams.
I have created a Fitting for this (rail edge marking front face) and use a centre rule however when adding this as a sub-method with overpassing Facade and underpassing Top I cant get it to work but works when added through cabinet properties Frontage-Fitting Link
See attached Polyboard Cabinet
Would like this as standard fitting on all cabinets with front rails
Dave
Guest(s) 29
