Material modifier thickness for 3/4”|Forum|WOOD DESIGNER
August 18, 2022 - 4:13 pm
Got it! Thank you.
August 18, 2022 - 2:15 pm
PolyBoard registers the correct thickness, even if you choose to display the size with less precision.
You can check this by going to Tools > Units
If PolyBoard displays a 1″ for 3/4″, you may be on 0 or 1/2″
units.pngImage Enlarger
Please let me know if I have understood correctly,
(This post will be moved to PolyBoard section)
August 18, 2022 - 2:03 pm
I added MDF to the material modifier. I did 1/2” thickness and it saved but when I type in 3/4” it changes to 1”. How do I fix this.
Guest(s) 37
