measurements issue|Forum|WOOD DESIGNER
measurements issue
Forum Posts: 1389
May 15, 2025 - 9:18 am
Thank you for letting me know.
Have a great day,
brendan kavanagh
Forum Posts: 226
May 14, 2025 - 1:04 pm
Hi Isaac
We adjusted the diameter of the tool it was 11mm and we ran a test this morning and its cutting to the right measurements now
Thanks Caroline
Forum Posts: 1389
May 13, 2025 - 1:48 pm
Hi Caroline,
I am not sure without seeing it, but if you measure the diameter you will know if it is no longer 12mm. If it is closer to 11mm, then this will answer your problem.
Let me know how this goes.
brendan kavanagh
Forum Posts: 226
May 13, 2025 - 1:34 pm
Hi Isaac
I have gone back to workshop with this and they have told me that the 12mm nesting bit has been sharpened would this affect the cutting???  Will i adjust the diameter of the nesting bit?
Thanks Caroline
Forum Posts: 1389
May 13, 2025 - 12:56 pm
Hi Caroline,
I do not believe that it is a problem with PolyBoard as the bottom component in PolyBoard is 964mm wide and the same component in VCarve is 964mm wide.
I recommend checking your tools and setup on your CNC machine.
brendan kavanagh
Forum Posts: 226
May 13, 2025 - 11:19 am
Hi Isaac
I have sent you the sheet that the 1000w bottom is on in vcarve will that help?  (the job is on 30 sheets)
How do i send you the post processor file?
Caroline
Forum Posts: 1389
May 13, 2025 - 8:02 am
Hello Caroline,
Do you have a copy of the VCarve file? The PolyBoard file seems fine to me.
Could you please send me a copy of your Post Processor in PolyBoard as well?
I will look into this for you.
brendan kavanagh
Forum Posts: 226
May 12, 2025 - 6:10 pm
Hi
we have cut out a kitchen but there seems to be a problem with majority of the top and bottom of units. eg attached 1000w unit bottom and rails on polyboard are 964mm but when cut out they are 966mm??? there seems to be an extra 2mm on each cabinet
What could be the issue?
Thanks Caroline
Guest(s) 33
Emmanuel Sacco: 179
Zaheer Abbas: 175
Tom Jackson: 133
Beth Hinks
Manuel Belmar
Colin Rouse
Steven mason
Chas Joy
Eduardo Montilla
Mounib osman
Sebastian M.
Tom McGranaghan
Mohamed Mekayed
Topics: 2874
Members: 522
