Miter Joints / Edge angle data|Forum|WOOD DESIGNER
November 30, 2017 - 3:23 pm
Hi Rafal,
The edge angle is printed on the project print out:
edge-angles.pngImage Enlarger
and also drawn into the dxf file of the part.
The edging material is calculated at it’s maximum length.
Hope this is helpful,
November 30, 2017 - 12:04 pm
Rafal Meckovski said
As on attached image: Example of how we would specify edging for this panel would be: 1 – 2mm ABS, 2 – 2mm ABS, 3 – [some amount of degrees, for example: 15°], 4 – no edge. All of this information I need on an Excel sheet. My question: where within the program can I find the information about this edge angle?
P.S. The wardrobe on this image is sloped wardrobe.pb-cab from Quick Design Libraries.
edge-question.JPGImage Enlarger
November 30, 2017 - 12:02 pm
November 27, 2017 - 11:24 am
Hi Rafal,
I don’t really understand your question;
are you asking if you can get drawings or indication of the 45° angle on the edging materials?
Polyboard will calculate edging the same length as the total board length, so if a board is 1m long and mitred the edging will always be 1m too.
November 27, 2017 - 7:35 am
I am having a problem with exporting the data about the egde angles. Lets say I have a miter joint and I want to export the data about the edge angles for the cutting list. How do I do that?
My work-around for now was to create an egde material, call it “45°” and create an edge style sub-method. It works for 90° joints but what about if I have non-90° angles?
Thanks in advance. wink
Guest(s) 72
Christian GLENET
mohammadmaghari
Petru
Trojan Construction
Islam Boukouiren
Topics: 2970
Members: 566
