Mortise & Tenon - hole cut-out spacing|Forum|WOOD DESIGNER
Forum Posts: 2110
When grooved you can use the Groove and oversizing sub-method to add spacing in length and thickness, but so you don’t have conflict when using a tenon, in order to add more space in thickness the easiest way is use a thicker panel.
All the best, Alexandre
Connor
Forum Posts: 62
February 22, 2021
OfflineI have set up mortise & tenon type shelves on my unit and i want to increase the gap of the hole that is cut out on the side panel, to allow a bit of spacing (from 12mm to 13mm).
What is the best/easiest way to do this? It would be the same everytime, so if i can save it somehow that would be great.
TIA,
– Connor
Guest(s) 61
Emmanuel Sacco: 176
Zaheer Abbas: 163
Tom Jackson: 122
Taras Orlyk
Jacob McKay
Juho Simuna
Nahuel Sena
Björn S
Paul Waldner
Bartek Witul
Diego Roa
ismail alrmadi
julian torres
Topics: 2845
Members: 511
© Simple:Press —
