NC file output for our Horizontal CNC borer|Forum|WOOD DESIGNER
Forum Posts: 1343
November 29, 2024 - 8:52 am
Nadeem,
PolyBoard will consistently follow the same patterns each time when exporting components. The rules are Top to bottom / Left to right / Front to back (depending on what component you are using).
See this further explained below:
Nadeem Lotia
Forum Posts: 53
November 29, 2024 - 6:33 am
Hi Issac,
Thank you for replies to first two questions, however I need reply on the below question
3- There is no part on face1 or face2 of the dxf Horizontal file, how to determine which face is which, this is sometimes important for the horizontal side machining.
to further explain, We need that all dxf exports are either having their face 1 or face 2 on the top of the dxf output. How do ensure that and how to know for sure that a certain face is facing upwards?
Forum Posts: 1343
November 27, 2024 - 12:11 pm
Hi Nadeem,
Thank you for your patience.
Question 1 & Question 2:
See the attached video,
Question 3:
The horizontal drillings are always referenced:
Top to bottom / Left to right.
Therefore, you are always referencing from the top of a panel, and from the left of a panel.
Forum Posts: 1343
November 26, 2024 - 4:04 pm
Hi Nadeem,
Sorry for the late reply. I am working on a response and should have it to you soon.
Nadeem Lotia
Forum Posts: 53
November 26, 2024 - 12:08 pm
Hello Issac,
Thank you for a detailed answer, I understand the current limitation of Polyboard, In your answer however, There are some further questions / requirements.
1- We would like the name of the DXf files to be in the format of  <Project Name><Cabinet Name><Part Name>, how to acheive that?,this is required for horizontal machining operator, to identify/locate the part by its sticker applied in the first operation. Our sticker is attached for your reference.
2- We get this message while setting up Multi Post processor, Please explain what it exactly implies?
Nadeem
Sticker-1.jpegImage Enlarger
02-1.JPGImage Enlarger
Forum Posts: 1343
November 26, 2024 - 9:10 am
Hi Nadeem,
If I understand your question, you would like a separate dxf file for each edge of a component with drilling information.
Currently, this is not possible with PolyBoard.
See a further explanation below:
Nadeem Lotia
Forum Posts: 53
November 25, 2024 - 7:17 am
Dear Issac,
Thank you for your feed back, this is very encouraging!
There is one additional information that I did not pass in my previous question. We currently use Optinest to output to vcarve, because OptiNest has the ability to produce the Stickers and PDF/DXF output which makes the sticker application on each individual work peice much easier. We are also already using face 1 / face 2 sensitive output.
The sticker output from OptiNest is <Project Name><Cabinet Name><Part Name> which is a requirement.
Thus far is no problem we are happy with it. We are able to import this into v-carve and process accordingly.
Now we would like horizontal Output from either PolyBoard or OptiNest,  Each part is a seperate file, which consist same naming convention as the sticker naming convention of OptiNest, with additional Left/Right/Top or Bottom indicater. Thus each Part will now have 4 additional possible dxf outputs for each EDGE of the part. I have enclosed a PDF which shows one such possible part.
Please guide us how can we configure this output?
Best Regards,
Nadeem
Forum Posts: 1343
November 21, 2024 - 8:33 am
Hi Nadeem,
Horizontal drilling is not possible with VCarve Pro.
You can output the horizontal drillings on PolyBoard for processing in another CAM software.
In PolyBoard, go to File>Multiple post processor options.
Here you can generate separate files for your horizontal tooling and exclude them from export into VCarve.
See more information in the following articles:
https://wooddesigner.org/help-…..processor/
https://wooddesigner.org/help-…..-drilling/
Let me know if you require further information.
Nadeem Lotia
Forum Posts: 53
November 21, 2024 - 6:59 am
We are using Polyboard dxf post processor to output file for vcarve, we have recently purchased a CNC horizontal drilling / grooving machine. We would ideally like to export the 4 edges of each part, along with the part name for gcode generation,(somthing similar to the two faces machining that we are using). Is that possible? if yes please explain how.
Nadeem.
Currently Online: Craig Firth
Guest(s) 48
Emmanuel Sacco: 176
Zaheer Abbas: 173
Tom Jackson: 124
Mounib osman
Sebastian M.
Tom McGranaghan
Mohamed Mekayed
Juan Carlos Izquierdo Hdez
Taras Orlyk
Jacob McKay
Juho Simuna
Nahuel Sena
Björn S
Topics: 2849
Members: 516
