Nesting angles again|Forum|WOOD DESIGNER
Hi Conor,
You should get the panels cut to net dims and only over sizing added, so should be OK.
Cheers,
January 28, 2018
Ness said
Hi both,Please make sure that in your Polyboard to Optinest post processor the dimensions are set to “Overall”.
Thanks Ness, everyday is a school day. This doesn’t impact on my gable hinge hole problem I had last week where the edging was not allowed for?
Regards, Conor
January 28, 2018
Hi all,
I’m doing my first under stair project and I added 10mm to chamfered edges as per my previous nesting angles post question/answer.
This all seemed fine and when I explode the drawing in polyboard there is 10mm oversizing showing.
However when I nested the panels I didn’t get the 10mm extra, I got the net size.
Is there something else to do in optinest?
Thanks, Conor
