Nesting issue|Forum|WOOD DESIGNER
Nesting issue
Forum Posts: 1822
June 18, 2024 - 8:52 am
Yes we have some moderator issue and we can’t upload files for now…. it’s why I have target the video
Never with a Nesting machine, oversizing is mainly for part-to-part CNC,
for example, to add 5mm to the periphery, this oversizing allows larger parts to be debited to OptiCut, on less careful or precise cuts, and therefore in the export PP to generate a calibration of 2.5mm per edge of the part in CNC.
*Tips by changing Sub-methode Groove & Oversizing to your classic -FS/standard, that update all panel in single action,
Conor Devoy
Forum Posts: 139
January 28, 2018
June 18, 2024 - 8:40 am
Good morning Alex, I changed all the pieces one by one in the corner cabinet to zero over sizing in polyboard and exported it to optinest.
That seemed to have worked.
What is over sizing, when would I use it?
Regards, Conor
Conor Devoy
Forum Posts: 139
January 28, 2018
June 18, 2024 - 8:28 am
Thanks Alex, is there supposed to be a video for me to look at?
Forum Posts: 1822
June 14, 2024 - 11:17 am
Which information I have,
From PB to our current PP, switch Overall Base Panel to Ignore ( video at 1.40, sorry I have issue I can’t upload Screenshot)
From OptiNest menu Tools > Options > DXF export (tab) , if not set set an overall base panel “PANNELLO”, in Red color and Polyligne type (as show at 2min of video)
Conor Devoy
Forum Posts: 139
January 28, 2018
June 14, 2024 - 10:04 am
Hi Alex, thanks for your reply but I don’t understand what I have to do.confused
Forum Posts: 1822
June 14, 2024 - 6:19 am
Conor ,
1°)After quick check on your project I’ll see all issues come from Wall_elle Cab and this cab is the only cab having Oversizing
and other cabinet having  -FS/standard groove & oversizing sub and Wall_elle are a L shape cabinet…
and all Parts have 2 DXF description ‘PANNELO’ and ‘V-Fraes-18’ Layer, and when both layer are superposed you don’t have issue,
but when they have an offset or and/or shaped parts, ‘PANNELO’ are recognized as Overall base panel and  ‘V-fraes’ inner tooling instead of Outline
2°) It will be interesting to know if this “PANNELO” layer is need per parts? or can by ignore from PB, then create on overall base panel from ON
And in this case only V-Fraes-18 should be used to describe parts and provided better Nesting
This solution will definitively resolve the various cases of incorrect sub-methods and shaped parts.
Conor Devoy
Forum Posts: 139
January 28, 2018
June 13, 2024 - 3:18 pm
Hi all.
I’m attaching my polyboard file and my optinest files of my current job.
I don’t know why but some parts are coming out in the nest as just an outline allowing other pieces to nest inside them.
Hope you can help.
Thanks, ConorNest.jpgImage Enlarger
Most Users Ever Online: 286
Guest(s) 17
Conor Devoy: 139
Zaheer Abbas: 96
Patrick Maylor: 63
Vicky Hope
Stephen Vis
James
douaihytech
Emmanuel Sacco
MateiCL
Brian Serrao
Allister Griffin
Martin Ahlström
luis parreira
Topics: 2158
Members: 287
