nill panel|Forum|WOOD DESIGNER
nill panel
September 26, 2023 - 2:49 pm
Sub-methods can be used to manage material thicknesses, which is not the case with Nil panels.
Zaheer Abbas
Forum Posts: 192
September 15, 2023 - 9:39 am
hello,
Why I can’t change a nill panel parameter from the submethod?
whenever I have a nill panel I can’t change its panel type from the material submethod, I need first to remove the nill panel manually and then assign the new submethod material, if I don’t do this the panel will remain nill even if the submethod has another parameters.
Guest(s) 43
