Numbering of parts when exporting for nesting|Forum|WOOD DESIGNER
almys111
Forum Posts: 9
January 9, 2026 - 12:33 pm
So simple and yet so efficient!!
Thank you
Forum Posts: 2128
January 9, 2026 - 12:11 pm
Of course! Based on our nesting solution, the best way is to set the cutting list option to Individual cutting list from the Cutting List Options menu.
almys111
Forum Posts: 9
January 9, 2026 - 11:28 am
I’m encountering a persistent issue with the numbering sequence during export.
When using export function, the numbering in the exported file does not match the exploded view or the print report. The problem occurs because the export assigns a unique sequential number to every part. As a result, whenever there are two or more identical parts in the cutting list, the numbering quickly becomes misaligned with the exploded view and the print report.
For a small cabinet, this is manageable. However, with projects containing 60–80 parts, the inconsistencies become significant and difficult to work with.
Is there a known solution or recommended workflow to prevent this numbering mismatch?
Thank you.
Guest(s) 33
brendan kavanagh: 227
Emmanuel Sacco: 196
polyjohn
Maxime Marengere
everslyjoinery
Topics: 2903
Members: 539
