over /underpassing locked.|Forum|WOOD DESIGNER
OfflineHello Ola,
You are working with Built-In doors here, meaning that the doors are fixed as in-set into the unit. As PolyBoard is referencing this as in-set, you need to manually adjust the recesses and overlaps of the units components. See an example below:
Offlinehi.
Trying another unit to see if it was the drawers or something that made it to not allow us to underpas anything. only overpassing. bus same results.
Can you Pleas advise on Why I am not allowed to deside if I want it to over or underpass? Sorry, but it drives me nuts…
Best regards Ola
OfflineHi.
We want the doors in this furniture to be overpassing the bottom. but cant changes neither the door or the bottom to under/ overpasing. they seems both to be loked to the doors underpasing and the bottom overpasing. there was no problem giving the doors shared edge / being overpasing to the verticals. so why does the program/settings dont aloud us to customize this?
ola
