Panel Generation failed|Forum|WOOD DESIGNER
Tom Jackson
Forum Posts: 136
April 13, 2026 - 9:53 am
The explanation about the hanging rail was very helpful yes – thank you.
Makes perfect sense and I’ve fixed the problem.
Cheers,
Tom
Forum Posts: 1663
April 10, 2026 - 9:12 am
Hello Tom,
Tom Jackson
Forum Posts: 136
April 9, 2026 - 2:12 pm
I forgot to add…the notch should be 10mm more in each direction for tolerance. Wall depth is 105mm, so a notch of 115mm (in the front to back axis (depth) and the other direction (left to right/width) is 91mm from the back left edge to the corner of the wall, so 101mm notch.
Tom Jackson
Forum Posts: 136
April 9, 2026 - 1:53 pm
I’m try to create a notch around the back left side of Cabinet B in the middle. The challenge is after the notch, I cannot then add a hanging rail. It says panel generation failed. I’ve tried both notching first then adding the rail, and adding the rail, then notching the cabinet, to no avail.
Any suggestions would be welcomed as this is a live job. I’ve attached the project file for you and upgraded to 8.10j for the software.
Cheers,
Tom
  • sp_PlupMedia ADawson_Bedroom_V1.zip(210 KB)
Guest(s) 34
Topics: 3003
