Partially sloped cabinet|Forum|WOOD DESIGNER
Forum Posts: 2128
April 2, 2021 - 11:03 am
This is another solution working too!
Cheers, Alexandre
April 1, 2021 - 11:08 am
Thanks Alexandre.
Just for others post’s readers, the option “Multiple Slope Top” is a choice in “Top” section on “Modify” menu. It took me a while to figure it out.
Meanwhile I was not able to design the cabinet using the suggested method as I wanted the slope to start at exactly the same height where a shelve (fixed) is located. I wasn’t able to manage the joint (groove) between the shelve and the sloped (2nd) top.
I had to revert to a solution without the top portion of the backside, cut by the shelve, and a sloped “free division”, to get a better control of the groove for the back panel (see attached cabinet). Let me know if can be a solution.
Cheers, Maurizio
Forum Posts: 2128
March 25, 2021 - 9:37 am
I think you should use “Multi-slope Top”  and use “Top (2)” as a sloped back
sloped2.pngImage Enlarger
example in 7.06B
sloped.pngImage Enlarger
All the best, Alexandre
March 24, 2021 - 3:06 pm
any idea on how to achieve a partially sloped cabinet like this. It seems I can add slope to back cabinet but I’m not able to add slope only at a certain height.Partial_slope_2.pngImage Enlarger
Partial_slope_1.pngImage Enlarger
Thanks for any help.
Maurizio
Guest(s) 40
brendan kavanagh: 227
Emmanuel Sacco: 196
polyjohn
Maxime Marengere
everslyjoinery
Topics: 2903
Members: 539
