PB synchronization between two computers|Forum|WOOD DESIGNER
June 17, 2021 - 9:22 am
It is not possible to synchronise an update. This is something you have to do manually. If you go to the forum in the subject polyboard you will find the first post called “Polyboard and Quick Design Libraries: New Feature Updates”. On this post on the page bottom, you can subscribe so that every time a new version is updated on our website you will be notified by email. It is then up to you to upgrade your version to the latest one on both computers.
It is important that your PB pro pp has the latest, same or higher version than the pro version otherwise it will not be able to open cabinet files from the pro version.
If you downloaded our quick design libraries you can set these as a shared folder on a dropbox or one drive. This will make sure both programs are working from the same source. You will have to point both PB programs to this particular location in order to work.
Puuslik
Estonia
Forum Posts: 46
June 16, 2021 - 5:25 pm
Hi!
I have two PC in my office with a PB Pro program, how can I sync and update their data?
Is it possible to set synchronization on automatic mode ?
One computer PB 7.02.c Pro PP version, with our own settings and generates today all production files for machines.
The other computer is running PB 7.06.f Pro and needs data synchronization to work.
BW!
Ain
Guest(s) 36
