Pocket door System|Forum|WOOD DESIGNER
OfflineHello Tom,
This is my recommendation for pocket doors. This may change depending on the specific system and drilling requirements you have.
OfflineHi Isaac,
I’m currently in discussions with Häfele around a range of systems they’d like us to offer. The recurring challenge I’m running into is how these components would be integrated within Polyboard from a parametric standpoint, and practically speaking. Would it be as simple as the pulldown rails (Single panel Fitting)? Would we only represent the holes or the fitting itself?
As an example, please see the link below. I’d really appreciate your thoughts on this one — does it look like something that could be built parametrically, and how straightforward do you think it would be to implement?
If possible, would you mind putting together a quick video to walk through how a device like this could be approached and set up in Polyboard?
[LINK] – It’s a pocket door system.
Keen to hear your thoughts.
Cheers,
Tom
