Poly and Vcarve|Forum|WOOD DESIGNER
Poly and Vcarve
August 2, 2023 - 4:00 pm
Hi Urmas,
The edging indication is not possible in v-carve. It receives the DXF files with all toolings and layer information but no extra information that is visible as edging or labels.
For the qty Polyboard automatically transmit the total qty with the output to our nesting software OptiNest which also indicates edging, labels , stock management, grain direction and perfect grain. The optimisation features on v-carve are standard only.
In order to get the correct qty from Polyboard DXF export to V-carve you need to set in Polybaord your cutting list parameters in the cutting list menu as follows
select individual cutting list
select ungroup models
Urmas Zahharov
Forum Posts: 2
August 2, 2023 - 1:36 pm
Hi!
 Is is possible to display edging and part names on the drawings in vcarve?
Also quantities, when for eg i have 5 fixed shelves, then there is also only one file and I have to remember to duplicate parts
Guest(s) 21
Topics: 3003
