Polyboard 7.07a1 Issues|Forum|WOOD DESIGNER
After analysis by the development team, here is their return.
Regarding the “Door / Top” and “Door / Bottom” links, please note that we have
extended the Fitting Links sub-method to the 2 door sides that are orthogonal to
the Fitting Side
Your issue is due to the fact that your Door links with Tops and Bottoms are global
and not selective, so when you switch the Fitting side
all new links will also apply.
In this respect, we would suggest that you use structures instead of fitting links
for feet and similar fittings
All the best, Alexandre
December 7, 2018
OfflineHi Team
I don’t know what is happening with these latest versions but something is not right.
We now have a couple of issues with door hanging
(1) when we change door hanging fitting side for some reason it brings through our feet fitting onto back of door also our front marker in top rail fitting changes from bottom to top?? see attached Base Cabinet 1 Door LH (from our library) and same cabinet (door hang RH) with described fittings.
(2) when we add a new door to a cabinet no hinge fittings come through ?? see Base Open Shelf (our Library) and same cabinet with door added also note it has changed top rail Front Marker fitting from bottom to top as well as.
Dave
PS We have invested heavily into Polyboard but with the OptiNest label issue and these issue your software is now becoming a liability for us
