Nevermind i manage to make solve it, by trying the options.
it is solved
April 14, 2018 - 10:10 am
Hello
I am having a problem regarding the horizontal holes and how they are exported to post-processor DXF
I analyzed the dxf file containing the side holes, and the problem is the direction of the extrusion.
In the picture below (pic. 1) you can see how the holes result in the DXF file that you gave me:
(edit: link no longer active so removed)
In order to import the holes as machining on the side face they should be oriented as shown in the following picture (pic.2):
and there is also the position option, that i don’t know if that has any impact on the DXF as well
Any idea on how to set polyboard to export the holes properly?
