Polyboard Cabineo Holes incorrect on one model|Forum|WOOD DESIGNER
Forum Posts: 697
May 9, 2025 - 1:12 pm
No worries. Let me know if there is anything else I can help with.
Patrick Maylor
Forum Posts: 84
May 3, 2023
May 9, 2025 - 12:00 pm
Hi Issac
I have now been through the XCS and the nesting and there seems to have been an issue and it looks like someone remade this with the holes in the wrong place and not as per the file.
Sorry for raising a non issue. (they will drive me mad one day)
Cheers
Patrick
Forum Posts: 697
May 9, 2025 - 11:44 am
Hi Patrick,
I am looking at the file and trying to understand what is incorrect. See the attached image, are you saying that when assembled this panel is on an angle?
Vertical-division.jpgImage Enlarger
Also, can you please send me a copy of your parameter file?
Patrick Maylor
Forum Posts: 84
May 3, 2023
May 9, 2025 - 11:25 am
Hi Isaac
Email sent, I checked in the 3D and 2D and all looks perfect, but for some reason the holes output in the file are not in the correct location.
Cheers
Forum Posts: 697
May 9, 2025 - 11:20 am
Hi Partick,
Please Zip the file and email it to [email protected]
In the email, please say that the file is for Isaac.
I will look at this for you. Regards,
Patrick Maylor
Forum Posts: 84
May 3, 2023
May 9, 2025 - 11:05 am
Hi
We just installed a cabinet but when we went to put the mobile shelves in the divider in the top of the cabinet was not vertical and is 5mm out.  On interrogating the model this is not the case, but when I went into more detail the holes for the cabineo in the fixed shelf are dead centre whereas they should be offset circa 5mm as per the cabineo model.  I wont be able to load the model onto the portal as its too big.  How can I get this to you as this is something that we have not had an issue with and now we have to uninstall the cabinet.  In the attached it is shelf 7 where the holes in the middle should be set off circa 5 mm to left
PAtrick
Most Users Ever Online: 365
Guest(s) 33
brendan kavanagh: 179
Tom Cleaver: 164
mark nichols: 162
Conor Devoy: 158
Zaheer Abbas: 132
Blake Simpson: 104
Patrick Maylor: 84
Tom Jackson: 83
EIlon Shperber
Alex Pop
Rick48
Hassan Sultan
Carmela Di Sorbo
Telmo Oliveira
Jesus Vergel
eduardo beiza
lucas Lucas Moreno
Topics: 2521
Members: 395
