Polyboard issues|Forum|WOOD DESIGNER
Polyboard issues
July 14, 2026 - 8:13 am
Hello John,
If you open and then save the file locally, and then re-open it, I believe the problem should be resolved.
When PolyBoard is searching for someone else’s server, that is not accessible to you, it can delay the software. After a save and re-start, this should recognise that it is rather running solely on your PC.
Please confirm if this is what you are after.
Ginae LTD
Forum Posts: 11
July 14, 2026 - 6:55 am
Dear Isaac,
We did try to be saving locally the textures each on his computer. System works perfectly with all the projects and models.
Our problem starts when we are trying to open files that someone else has prepared. We are located in different locations and finding a solutions to this problem will really be appreciated.
Do let me know if there is any more information that your technical team may need.
John
mark nichols
Forum Posts: 169
July 13, 2026 - 1:57 pm
Hi Isaac
Please send me any info on remote textures as well, our are served from a network server
Mark
Ginae LTD
Forum Posts: 11
July 10, 2026 - 9:13 am
Dear Isaac,
Thanks for your reply.
Will speak with Maria to get the info you sent.
John
July 10, 2026 - 9:05 am
Hello John,
Thank you for your patience.
Our development team has identified the problem that you are having. The delay is related to the textures being loaded from a remote network location rather than from the file itself. The delay is not an issue with your software, rather an access problem from your network drive.
I have forwarded more comprehensive information to Maria via email.
Ginae LTD
Forum Posts: 11
July 9, 2026 - 2:23 pm
Hello, Isaac!
The version we are using is 8.11c.
John
July 9, 2026 - 10:15 am
Hello John,
Can I please confirm what version this is for?
Thank you for all feedback.
Ginae LTD
Forum Posts: 11
July 8, 2026 - 3:45 pm
Dear Isaac,
Just downloaded the latest version and did a testing to see if anything has changed with the delay issues.
Tried the following
1. Material without grain direction and 3d tooling deactivated. ( good reaction time )
2. Material with grain direction and 3d tooling deactivated. ( good reaction time )
3. Material without grain direction and 3d tooling activated. ( good reaction time )
4. Material with grain direction and 3d tooling activated. ( bad reaction time )
No idea if this is helping at all to your solution research, but we are all waiting for this solution ASAP
John
July 2, 2026 - 12:33 pm
Hello Maria,
I have sent you an email with more information.
Ginae LTD
Forum Posts: 11
July 1, 2026 - 1:29 pm
Hello, Isaac!
I confirm that my laptop meets the minimum system requirements.
Mariq
Guest(s) 40
