Polyboard & Mach3 CNC Integration|Forum|WOOD DESIGNER
May 10, 2022 - 7:31 am
Hi Pieter
Artcam is a discontinued product so no longer supported. It originated from Autodesk. It should be able to do it but it depends if it has a mach3 postprocessor.
May 9, 2022 - 8:17 pm
Thank you for your response, will ArtCAM do the trick?
Pieter
Fatima
Forum Posts: 13
May 9, 2022 - 10:10 am
Hi Pieter
Thank you for reaching out!
Mach 3 requires a G-code file format. Unfortunately, Polyboard does not have a Mach 3 postprocessor but it can be done via V-carve eventually as they have the mach3 PostProcessor.
I will get in touch with you via direct email for further details.
Have a great day!
May 9, 2022 - 3:35 am
I would like to know if Polyboard can Post to a CNC machine that uses Mach3 CAM software? I don’t want to purchase a full license before I’m sure that it can talk to Mach3.
Warm regards,
Pieter Muller
Guest(s) 44
