Possibility of rotating on edge?|Forum|WOOD DESIGNER
Forum Posts: 1081
OfflineHello Tarjei,
At the moment this is not possible in PolyBoard. What you can do, as you already have set up in your PP, is to offset any profiling away from your bottom edge.
Sorry that I cannot be of more help here.
Marianne Hagen Olsen
Forum Posts: 36
September 29, 2021
We use a drillteq v200, which means that we can only process 3 edges at a time. And there is a limit to how close to the material clamp we can do a machining.
To bypass this limitation: Is it possible to setup a Multiple PP, similar to face 1 and face 2 rotation, but for edges? Like “edge 1” will do profiling and machining, but no machining on the bottom edge, and “edge 2” is rotated top-bottom and will only do machining on the remaining edge.
Hope this makes sense.
Tarjei
Most Users Ever Online: 704
Currently Online: Zaki Brijawi
Guest(s) 65
brendan kavanagh: 205
Conor Devoy: 158
Zaheer Abbas: 154
Patrick Maylor: 108
Tom Jackson: 106
Maciej Jaworski
Eleanor Maple
Filip Godu
Erik Rickert
Brandon Januarie
David Triller
Nathan Bruton
Michael Okyere
Timo Pitkänen
Topics: 2725
Members: 470
© Simple:Press —
