Hi Jan,
This option is scheduled to be performed in mid-term planning. Probably with the next major release PolyBoard 8
May 18, 2014
Hi Jan,
The developers informed us that there is no tool reference needed in drilling as it should be detected automatically.
According to our knowledge, no other information is required
in the Biesse PP as the tool should be automatically identified.If you learn more in this respect, please let us know.
Can you run a small cabinet and export the CIX file and show the process you go through on a video? The developers would then perhaps be able to analyse this better. You can eventually share the video link here on the forum or send the video file to us via WeTransfer on email support@wooddesigner.org.
May 18, 2014
Hi Jan,
also when you pull in a file you need to hit the start upload button before sending the post
Hi Jan,
These were not uploaded. Please compress first as zip file and upload again
May 18, 2014
Hi Jan ,
I will call tomorrow morning around 9H30
Hi Jan,
I tried to call you, but the numbers we have are no longer valid. Do you need any specific format for your machine? Our pp can output the CIX and CID files. Both pp can be set up for all machining types.
May 18, 2014
@Michel
Dear Michael,
I have access to a Biesse Brema 2.0.
The post processor contains an export to Biesse .CIX instead of bSolid.
Now I have to select and assign all drills separately.
Is there a way to assign all drills directly from Polyboard?
thanks in advance for your answer
Mvg Jan
