Post Processor Outputs |Forum|WOOD DESIGNER
To be confirmed according to the version but it seems to me that in this case it will be necessary either to export in CIX or CID to send each part to make an optimization with Bnest, or via Polyboard and Optinest by configuring the layers for Bsolid,
when the time comes, don’t hesitate to contact the support team if you need PostPro training to help you in this process
All the best, Alexandre
December 7, 2018
OfflineWe are purchasing a second CNC which is a Biesse Rover S FT 1236 NBC, it will be running B Solid software with B Nest also with an output for the automatic labelling function.
We have both Polyboard Pro PP and Optinest which we presently output to Enroute for our existing CNC.
Do we have the outputs presently for B Solid and B Nest? I believe they are CTX files.
Cheers
Stu
