December 7, 2018
To be sure, I need to know your whole process.
For information,
With Nesting solution, PolyBoard > OptiNest
Milling of parts with edge thickness deductions > PostPro setting to Net Dim.
Milling of parts without edge thickness deductions > PostPro setting to OverAll Dim.
With a part-by-part solution, PolyBoard > OptiCut
Pre-cutting part with Oversizing > sizing and drilling on CNC > Edge bander with pre mills
PB cutting list option Net Dim for OC, edges thickness 0mm! > CNC PP setting OverAll Dim
Net Dim = OverAll Dim - edges thickness + Oversizing
For exemple,
parts 600x600mm with 5mm oversizing and edges 2mm
The part in the cut list is 601x601, which leaves only 1 mm for the part size on the CNC instead of 2.5 mm per panel edges.
All the best, Alexandre
December 7, 2018
To avoid conflicts with panel cutting or machining
the easiest solution is to set edge thickness to 0mm
