Print Selection|Forum|WOOD DESIGNER
May 18, 2014
Hi Dave,
I had this problem when I first starting using Polyboard. One way around it is to print to PDF file. Then from the PDF file you can select the pages you require to print. I eventually found this a bit of a pain and now use a tablet in the workshop.
Hope this helps
Tom
December 7, 2018
Hi Team
Is there anyway we can setup to print a selection of pages in one go?
For our factory drawings we print some of the Drawing & Tooling of Cabinets details but not all.
For example we have a job which has over 800 pages (see attached screenshot) but only want to print certain identified pages.
Polyboard will only let us print All or From-To and will not let us select the actual pages we need to print. We have not been able to find anyway to change this.
At the moment we have to print each individual page one at a time which especially in this job is very time consuming and frustrating.
Dave
