Problem with FREE DIVISON|Forum|WOOD DESIGNER
Hello Hung Vu,
I tried to play around with sloping shelves – and you are right, seems like PolyBoard is measuring the distance not from where you tell it, but from some abstract point (not even the middle).
There is solution though:
(“image1.jpg” – marked with red: ignore those numbers, they are not correct (if you add them up, you will see that the result is bigger than internal cabinet volume). “image2.jpg” – refer to those numbers – they are correct.)
You need to move your shelf (or free division) up or down, by guessing – sorry but I dont see other way that I know of, although it doesnt take long. With my cabinets dimension and that shelf slope set to 10degrees, I set it 182mm from the Top in the Properties panel and then it is 100mm from the top front to that shelf front – check polyboard file I attached.
Hope it helps 🙂
Hi all,
I try to draw shoes cabinet with shelve slop – i use FREE DIVISON for slop – but i have problem: I want to shelve 100mm from TOP in Frontage but PP can not understand – Maybe it do 100 on between. I tried 02 way with Free Division: first i choose Top 100 and slop – can not make i want – and second: i slop 10 degree first and then i back 2D to change dimension from TOP 100 but can not. it’s just like my picture – But i want distance from TOP on Frontage not between
Please help me
Thank you
