Problem with the software|Forum|WOOD DESIGNER
Forum Posts: 1441
sp_UserOnlineSmall Online
January 23, 2025 - 8:06 am
Hi Martin,
Yes please. I will follow the same processes you are and see if I get the same results. If there is a problem, I will need to narrow it down.
Thank you,
Rune Fagerli
Forum Posts: 26
January 22, 2025 - 1:19 pm
it is not a specific cabinet. i just open one template and and work with fixing holes etc and when i confirm changes on f example hole for dowel. the program closes.
chall i just send you and file of a new cabinet then?
Martin
Forum Posts: 1441
January 22, 2025 - 8:35 am
Hi Rune,
Can you please send me the cabinet file that you are having problems with? Additionally, a copy of your parameters please.
I will see if I can find a problem.
Rune Fagerli
Forum Posts: 26
January 22, 2025 - 7:19 am
i’m working on cabinet methods. almost each time i press OK in the window for apply the changes it rund 2-3 sec then polyboard closes. i then open again and have to press apply the changes from previous work.
some update required?
Best Regards Martin
Currently Online: Nadeem Lotia, Isaac, LORIN STANCIU
Guest(s) 49
Timothy Bennett
Members: 536
