quick design library|Forum|WOOD DESIGNER
Hi Mike,
DO NOT install again as this might over write the changes you have made to your libraires.
Instead just use the QuickDesign ¨Parameters button to point Polyboard to the new library locations.
You have to do this every time you change the library locations.
If Polyboard can’t find the libraries it will revert back to the default libraries.
Hope this is helpful,
July 21, 2018
I have made a huge error! I moved the library folder from my desktop to another folder, and then opened polyboard. It has somehow lost the connection to the files, even though I’ve moved the folder back to the desktop. I have also failed in my attempt to import again, should i run the installation program again? If i do that will it re-install the changes I’ve made to the fittings/rules etc?
HELP! :/
