radius curve in a panel|Forum|WOOD DESIGNER
brendan kavanagh
Forum Posts: 226
February 18, 2026 - 1:15 pm
Hi Isaac
thanks will try that
Caroline
Forum Posts: 1388
sp_UserOnlineSmall Online
February 18, 2026 - 11:57 am
Hi Caroline,
Yes, you can trace the curved radius with the “Draw Arc” tool in VCarve.
Then, assign a toolpath to it with the desired tool.
brendan kavanagh
Forum Posts: 226
February 18, 2026 - 11:39 am
Hi Isaac
re these radius curves attached is vcarve file Brendan is asking can we use the 4mm end mill at the end to go on the curve or not?
Thanks Caroline
brendan kavanagh
Forum Posts: 226
February 17, 2026 - 4:50 pm
Hi Isaac
apologies yes of course its a square wink  we have adjusted 2 measurements to 100mm and we can now do the curve
Thanks again
Caroline
Forum Posts: 1388
February 17, 2026 - 3:49 pm
Hello Caroline,
I am sorry, but I don’t understand your request.
If each side has a dimension of 200mm, you would have a square, rather then a corner cabinet.
This attached PDF is not possible.
brendan kavanagh
Forum Posts: 226
February 17, 2026 - 2:52 pm
Hi Isaac
thanks for the video, i have done a panel in polyboard (see attached) but can’t get all sides to be 200mm as in sketch for me to then do the curve can this be done?
Thanks Caroline
Forum Posts: 1388
February 17, 2026 - 1:20 pm
brendan kavanagh
Forum Posts: 226
February 17, 2026 - 10:51 am
Morning
Please see attached sketch could you advise how this can be done?
we want to do several different radius (5,7,9 and 11)
Thanks Caroline
Currently Online: Isaac
Guest(s) 23
Emmanuel Sacco: 179
Zaheer Abbas: 174
Tom Jackson: 133
Beth Hinks
Manuel Belmar
Colin Rouse
Steven mason
Chas Joy
Eduardo Montilla
Mounib osman
Sebastian M.
Tom McGranaghan
Mohamed Mekayed
Topics: 2873
Members: 522
