regular drillings |Forum|WOOD DESIGNER
regular drillings
September 21, 2022 - 12:36 pm
this is not possible with regular drilling, they follow the zone or panels where you have activated regular drilling,
For drilling follow selves you should create link with rules following shelves
like into attached screen shoot
drilling-1.jpgImage Enlarger
5 drillings per shelf a 37 from front and back following underpassing panel (37-37/xxx-n)
This solution has several advantages:
– Less drilling
– More efficient, especially with customised design
– significant time savings in nesting
All the best, Alexandre
brendan kavanagh
Forum Posts: 236
September 21, 2022 - 11:59 am
Hi
See attached unit, we set our adjustable shelves back 10mm from front and the regular drillings are set at 40mm on gable from back and from front. but when we adjust shelf say to 20mm from front is there a way to set the regular drillings to also move back with the shelf or do they always relate to the gable (I cant remember if there is a setting) and this has to be changed manually?
unit attached
Caroline
Guest(s) 61
brendan kavanagh: 236
Emmanuel Sacco: 210
Zaheer Abbas: 201
Tom Jackson: 142
Rooms Made Simple: 132
MobLux
Valentin Zarzara
Kendal Anderson
Sarah J0hnson
Andreas Nygårds
Nicolas LEBRETON ROOST
Luka Savić
Lee Gent
A S Brighton
Tobias Briander
Topics: 3062
Members: 602
