Removal of Drawer Fronts on added drawers|Forum|WOOD DESIGNER
Rooms Made Simple
Forum Posts: 41
September 1, 2022
January 6, 2024 - 9:35 pm
Thanks Alex.
Forum Posts: 1920
December 6, 2023 - 4:11 pm
Any elements can be defined by defaults with materials sub method’s
https://wooddesigner.org/help-…..g-methods/
Rooms Made Simple
Forum Posts: 41
September 1, 2022
December 6, 2023 - 2:59 pm
Hi Alex,
  Thanks for the speedy reply. It appears the last option is the one I was already doing. I set up a material called “Dummy” and this is what I use. Is there a way to default doors and draw fronts to this material instead of going into each one and changing?
Dean
Forum Posts: 1920
December 6, 2023 - 2:03 pm
First of all!
For drawers, it’s quite specific, you need to keep in mind that the drawer front is the reference for your drawer box!
-For the drawer don’t reduce your cabinet box you can set frontage in Outer mode from properties menu
frontage-outer.pngImage Enlarger
– In some case, you can define the front as Nil, but I don’t recommend it.
Nil.pngImage Enlarger
The best solution is to define a non-exportable material, by creating false façades and unchecking the exportability from panel materials.
false-facades.pngImage Enlarger
Rooms Made Simple
Forum Posts: 41
September 1, 2022
December 6, 2023 - 12:49 pm
Morning folks,
  First time forum user so please be gentle cool
I mainly create wardrobes and chests of drawers using Polyboard, and at the moment do not hardware on any of my models as I do this manually for the moment.
When I create a set of drawers, I start with a box that I have a saved template for. I then add applied draws which I have set up specifically to work with the tandem system, however this then deducts 20mm approx from my cab depth as the frontal is added which is annoying. I usually do not make the frontals as I add these later from another supplier so have no need to add them to my model. Is there any way I can add draws without automatically adding the frontal? I still need the counter-frontage, just not the frontals. Picture attached.
Many thanks
Dean @ Rooms Made Simple.
Most Users Ever Online: 365
Currently Online: sean mcmullan
Guest(s) 35
brendan kavanagh: 156
Conor Devoy: 146
Zaheer Abbas: 119
Blake Simpson: 104
Patrick Maylor: 74
Robert Coxhead: 74
Andrej Potočnik
Olga Safari
Greg Allen
Maximo Vinet
ben levene
roni ben ami
Kateryna Druzenko
Joseph El Hajj Moussa
razvan george tomas
Dennis Nwachukwu
Topics: 2341
Members: 350
