Scale problem in Polyboard|Forum|WOOD DESIGNER
Hi Walter,
The output of the Polyboard DXF is set with the units options.
I regularly open these files in Draftsight, AutoCad and SketchUp and always get coherent units.
As well as this , we have hundreds of people using these DXF files to run CNC so the units have to be consistent.
I suggest you look closely either at the application that you are using to open the files, or the set up of the units in your version of Polyboard.
Thank you for your quick reply
The problem is in the the output format of the dxf file
I’m set the parameters correctly, however when it is read into a import the values are 1000 x too big
Using eDrawings 2016 x64 Edition
(edit: link removed as no longer active)
-Walter
Guest(s) 16
Duayne Naugle: 129
Patrick Maylor: 60
dziekan
AKM
Topics: 2095
Members: 258
© Simple:Press —
