February 8, 2022
When you create a new cabinet, you can work with the default part or in the area and deactivate them all.
If you only work with your back, you can edit it easily!
Hope that's helpful, Alexandre
Matthew Murphy
February 8, 2022
Hi sorry by scribes I do mean filler panels/cover panels that will be fitted next to a wall, I had only successfully made them while attached to a cabinets so far. what we where really after was the ability to quickly add a scribe as a separate entity in catalogue mode.
thanks
Hi Matthew,
Can you explain in more detail what you mean by scribes?
If I understood correctly scribing a panel is making an indication to create a perfect cut along a non-linear surface.
Filler and cover panels are part of the project mode where they can be created as separate entities.
Matthew Murphy
February 8, 2022
Hi, Alex
I had already watched those but have just been back to watch again in case I missed something. unless I'm miss understanding something i guess there is no way to make a scribe as a separate entity from the carcass as I could not see anything in those videos.
thanks again
Matt
We recommend that you watch this series of short videos for explanations.
https://wooddesigner.org/help-.....d-methods/
All the best, Alexandre
