Setting up a groove on front edge and fitting reference point|Forum|WOOD DESIGNER
Forum Posts: 1742
February 10, 2021 - 8:24 am
Sorry I missed your post!
Maybe you can try with surface split and fittings?
groove-1.pngImage Enlarger
All the best, Alexandre
February 9, 2021 - 8:07 pm
Any ideas? 🙂
January 15, 2021 - 2:36 pm
Hi!
I am facing an issue rebuilding my manufacturing methods.
Attached pic and cab file.
  • What I want to achieve is a groove on cabinet bottom front edge 3x8mm in full length.
  • Cabinet side to bottom link reference from the panel front edge, not assembly front edge.
Bottom is made from assembly because it uses a bar material as handle. And I want that for the cutting list..
I see that i can now add a fitting link between surface splits. I can groove that way but it is not very parametric.
Or is there another workaround for this kind of setup?
Thanks!
Karl
Fitting.pngImage Enlarger
Guest(s) 22
Duayne Naugle: 129
Ray: 59
dziekan
AKM
Topics: 2089
Members: 258
