Setting up a specific manufacturing method-Video|Forum|WOOD DESIGNER
March 27, 2019 - 6:26 am
Hi Shafeek,
To set up your sub method:
– create a copy of the nearest existing method ie one of the H methods
– in the use the Order Priority section click Top to select it,
top_prio_010.pngImage Enlarger
this should make the Top pink in the drawing
top_prio_020.pngImage Enlarger
-Click the UP arrow several times until the Top moves to the top of the list and the drawing shows it Over Passing the sides
top_prio.pngImage Enlarger
To get the bottom raised by 100m :
– in Recess and Overlap rules clcik the + button to add a rule
br010.pngImage Enlarger
– in Parameters, Over Passing panel list select the Sides
– in the Under Passing panel list select the Bottom
– in the Propetrise list set Overlap to 100
br020.pngImage Enlarger
Your drawing should look like this:
br030.pngImage Enlarger
You can rename the sub method to suit.
Hope this is helpful.
March 26, 2019 - 11:12 pm
Have the methods in the Boxful submethod changed as compared to the vedios.
The current method list have lesser ones as compared to the video.
Where can I get to read on how to setup my manufacturing methods ?
eg I want to make a method similar to the bedside table shown in the video, where the Top is overpassing and the bottom is inside the sides and raised by 100mm. Where can I get to learn how its done ?Boxful.jpgImage Enlarger
Sidetable.jpgImage Enlarger
Shafeek
Guest(s) 44
brendan kavanagh: 227
Emmanuel Sacco: 196
polyjohn
Maxime Marengere
everslyjoinery
Topics: 2903
Members: 539
