setting up drawer style in manufacturing methids cab.|Forum|WOOD DESIGNER
May 22, 2019 - 12:26 pm
thanks i will upgrade…
May 22, 2019 - 12:15 pm
Yes,
Adding structures to manufacturing methods is only available in Polyboard 7
Actually in PB6 you can only add them to the structures lib, and paste and copy to another part
All the best,  Alex
May 22, 2019 - 12:07 pm
So are you say i cannot do that drawer in manufacturing methods on plly6 pro….and i have to do a upgraded licence to polly7
May 22, 2019 - 11:42 am
Hi Again,
I forgot to say something,
What I showed you in the previous post is for Polyboard 7, this version isn’t free if your current version is Polyboard 6.
If you are in 6 version you can only add structures to the library
Cheers Alex
May 22, 2019 - 10:04 am
Hi I did download and instaal it..how do i reactivate it…in new version?
May 22, 2019 - 9:48 am
hi alexsomewhere i miss something…
see my attacedpic.. i do not get to the same place as in your pic…
May 22, 2019 - 9:15 am
Go to Download page
To get the latest version install it without uninstalling your current version
Launch Polyboard.exe, a windows will open to help you to complete the process
May 22, 2019 - 9:07 am
Thanks Alex.. Icannot open the c5-edit.pr-cab  should i download a later version op pollyboard to open the cab… how and where do i do that.
May 20, 2019 - 8:37 pm
First you must add a structure to the library
ADDlib.PNGImage Enlarger
Then add this structure to a Materials Style sub-method
MAtsty.PNGImage Enlarger
See the result in your cab I have edited, so you have built-in drawers and that free space 😉
Hope that’s helpful,
All the best, Alexandre
May 20, 2019 - 9:03 am
Hi.
in the cab attached.
i want to set up my drawers and doors in the manufacturing methods ..my fronts are split surfaced and the second face is then assembled… how to get this in methods is my problem..
thanks
Paul
Guest(s) 41
Conor Devoy: 173
Jan Peter Oelen
ANDI MÖÖBEL - Tarmo
Topics: 2964
Members: 562
