Shelf notch|Forum|WOOD DESIGNER
Only solution I think, is to set Right to Nil, or No in general options,
And use a vertical division with tenon, but this won’t let you use another fittings link
attached example
hope that’s helpful,
Cheers, Alexandre
Sorry, but I’m not sure I understand,
Can you send me a picture of what you want,
Cheers, Alexandre
Conor Devoy
Forum Posts: 174
January 28, 2018
OfflineHi all, I have attached a basic cabinet.
I have reduced the right hand gable by 100mm and I want the shelf to notch around by the 100mm and the thickness of the gable.
I’ve tried over passing the shelf and using inner tooling but it seems to cut through the gable.
Help please.
Thanks, Conor
Guest(s) 60
Christian GLENET
mohammadmaghari
Petru
Trojan Construction
Islam Boukouiren
Topics: 2970
Members: 566
© Simple:Press —
