shelf size difference |Forum|WOOD DESIGNER
February 26, 2025 - 9:10 am
I need the:
– pgmx files that are having the “standby” problem.
– The contact email address for scm.
Thanks.
February 26, 2025 - 8:52 am
Hi Emanuel,
I haven’t yet, please email them to me.
Emmanuel Sacco
Forum Posts: 198
Isaac said
Hi Emanuael,
No problems, send me the file.
Also, please respond to my email from yesterday when you have a moment. I need some more information before I contact SCM Maestro for you.
ok ask me what you need
Emmanuel Sacco
Forum Posts: 198
February 26, 2025 - 8:46 am
Isaac said
Hello Emanuel,
I still need you to email me the file and the contact email address for SCM please.
i send now the files attached and andress i am going to usk tony .
let me know if you recived the files yes or no.
thks
Emmanuel Sacco
Forum Posts: 198
February 26, 2025 - 8:44 am
Isaac said
Hello Emanuel,
Emmanuel Sacco
Forum Posts: 198
February 26, 2025 - 8:39 am
Emmanuel Sacco said
good morning .
as far as i know i send the file but in that case you already have it ,it is the project i send to you to check with scm .The piece is the one with shelfs it is positined the first one from the entrace.On that project while esembling and cutting i notice other small issue.Were i have the internat upriths the shelf holes are made doubel ,two rows on the back and two rows on the front .
thanks again .es
I ma trying to look for the error because i am thinking i make something wrong ,on the print prieview and 3d view doesnt show the extra holes of the internal sides .
Hello Emanuel,
Emmanuel Sacco
Forum Posts: 198
February 26, 2025 - 8:31 am
good morning .
thanks again .es
February 25, 2025 - 11:20 am
Hi Emanuael,
Emmanuel Sacco
Forum Posts: 198
February 25, 2025 - 11:11 am
Dear Isacc
GOOD MORNING
First of all thank you for yesterday help.
I having a strange issue with some shelf .I do not know if it is a setting or something wrong from my side but its strange how a shelf is cut around 6 mm shorter than another one in the same project .I will send you the file to take a look because its the second time that happens on different jobs.If you thake a look to the print preview you can see that even between plinth and shelf there is 1 mm difference .
Guest(s) 36
