Single panel editing slow/clunky |Forum|WOOD DESIGNER
Forum Posts: 1663
November 21, 2024 - 8:20 am
Scott,
If you want the oversizing (as you added in the project) then you need to set up as shown in the following image.
ON-Setup.jpgImage Enlarger
Note: This will give you the overall panel size even when you have angles etc. in your components.
I have done some more digging into why you are experiencing lag.
When you use a parallel desktop to emulate windows, your computers speed will stay limited.
I have come across the following article. I am not a mac user, and I don’t know much about the process or if this is helpful, but it may help or just be informative.
scott powell
Forum Posts: 27
November 20, 2024 - 12:12 pm
sorry im a bit confused about what you were asking at the end
I want it to add any over sized panels to optinest and then cut on Cnc – surely this should be a simple thing the software should do?
also can you look at that project and then edit single panels by moving the lines etc – when I open the edit single panel window it is really slow
Forum Posts: 1663
November 20, 2024 - 11:48 am
Hi Scott,
See the video below.
scott powell
Forum Posts: 27
November 20, 2024 - 10:23 am
sent via email
Forum Posts: 1663
November 20, 2024 - 10:04 am
Scott,
I am looking at these files now, I don’t yet see anything. Two questions:
– Please send me your OptiNest parameters (in optinest go to Tools>save parameters).
– What PP are you using? Is it the “OptiNest-VCarve-EN-Hori”
scott powell
Forum Posts: 27
November 20, 2024 - 9:38 am
hi Isaac it happens in the same project as what I have sent to you via email regarding hollow parts
Forum Posts: 1663
November 20, 2024 - 9:35 am
Hi Scott,
Do you have a project you would like me to look at? I can see if there is anything that could be causing lag in the software.
scott powell
Forum Posts: 27
November 20, 2024 - 7:00 am
when editing single panels in project mode
it is really slow/clunky to where it is difficult to work with
Polyboard 7.12d
Mac M1 Max 32GB Ram
Parallels pro
Guest(s) 22
Topics: 3003
