Sliding Doors|Forum|WOOD DESIGNER
Sliding Doors
Forum Posts: 1583
October 8, 2025 - 11:12 am
Thank you Mark,
Yes, I recommend continuing with Single Panel fittings for the time being.
mark nichols
Forum Posts: 169
October 8, 2025 - 10:52 am
Hi Issac
Just some little plastic rollers and plastic track
Nothing special, but its quick and ‘toolable’ for CNC without ali tracks etc.
It’s fine, I can tool the track grooves with normal links and just add the recessed wheels with single panel.
Hope you are well..
Mark
Forum Posts: 1583
October 8, 2025 - 10:47 am
Hello Mark,
For the moment, the Single Panel fittings are the best option for applying fittings to most sliding door set ups.
What sliding door system are you using?
mark nichols
Forum Posts: 169
October 8, 2025 - 10:43 am
Hi
Very rarely do I encounter something I can’t solve, but is there a way of tooling fittings to each individual leaf of a sliding door (two doors +) without using single panel fixings to achieve?
There doesn’t seem to be a way of applying fitting individually to each door.
Mark
Guest(s) 35
Conor Devoy: 173
Jan Peter Oelen
ANDI MÖÖBEL - Tarmo
Topics: 2964
Members: 562
