Sloping Lead In and Depth per Cut|Forum|WOOD DESIGNER
April 12, 2018 - 8:16 am
Hi Rafal,
I’ll send these requests to the developers at Boole.
best,
April 10, 2018 - 10:39 am
We are very happy with PolyBoard’s ability to put all the relevant data into .hops files but we would like to have greater control over some machining parameter.
When it comes to exporting parts as .dxf – the parameters like tool lead in can be modified after exporting them from polyboard (after all .dxf is just a geometry file). This is not true for Holzher’s .hop files: all the parameters (except milling speeds and some other) like tool number, tool lead in, depth per cut and so on need to be specified at the export in PolyBoard.
Could we expect some of additional parameters added in the future?
Parameters that we would like to have control over in PolyBoard:
1. Tool lead in with Z interpolation (sloped lead in).
2. Depth per cut and Amount of milling steps.
It looks like it should be very easy for the developers to add those features since all that the possible Polyboard update should be able to do is to change some numbers:
Below is the example of Starting Point line of code in .hop file. Each number (or text) is specifying either a machining style or giving information about dimensions and depths and the placement of the number withing that line of code is important.
SP (1210,490,-19.2,1,-1,_ANF,0,0,0,0,0,0,0,10,0,0,0,0,0,0,0,0,0)
SP – means starting point and is followed by the coordinates in x and y as well as depth in z (-19.2 mm in this case).
1 – Tool lead in mode. Polyboard can already export them as 0 – no lead in, 1 – Linear Lead In, 2 – Radial and 3 – Lateral
We need an option for what HOPS calls “Z Interpolation” and it’s basically just adding a minus sign to that number, so -1 is Linear lead is with Z interpolation, -2 is Radial Lead In with Z interpolation and so on.
10 – depth per cut in mm
0 – amount of cuts (0 for full cut, unless depth per cut is specified)
Guest(s) 50
brendan kavanagh: 236
Emmanuel Sacco: 210
Zaheer Abbas: 201
Tom Jackson: 142
Rooms Made Simple: 132
MobLux
Valentin Zarzara
Kendal Anderson
Sarah J0hnson
Andreas Nygårds
Nicolas LEBRETON ROOST
Luka Savić
Lee Gent
A S Brighton
Tobias Briander
Topics: 3062
Members: 602
