Small bug in PolyBoard|Forum|WOOD DESIGNER
Hi Both,
I’ve also often noted this bug and will inform Boole
all the best,
hi,
Polyboard only revers link as you revers panel propriety
I have the fitting links like on the Image 1 (Back overpassing all other panels and fitting links set to only appear when this is true. I have even specified that when the opposite is true – back is underpassing then fitting link set to 0 (none))
The bug appears when I change panel priorities in Boxful sub-method. I change them to Back underpassing everything else and fitting links do not dissapear (Image 2) – they should since i set in fitting links: when back underpassing all other panels, then fitting link is none.
When I change panel priorities manually in Properties tab then everything works like expected.
Am I doing something wrong or is it a bug?
Cheers!
