Store Front Counter|Forum|WOOD DESIGNER
OfflineHi again, the optimisation isn’t included with this CabinetFile service. You would need to buy at least OptiCut 50. Here’s a link to our OptiCut sales page for more information. Best regards, Stefan
OfflineHi, we’ll redo these files for you by the end of the day so you have imperial units. Best regards, Stefan
Hello SlickDesigns,
I am uploading the plans, cutlist, and dxf files for “ProperPaws-Front-Counter-Final” project file so you can have a feel for how it looks.
I just have few questions and comments:
1. If you started working on a cabinet in a Cabinet Mode, you can easily put it into project – Have both project and cabinet file opened and while being in you cabinet file click on Project/Cabinet Switch (image “”1.jpg) – the cabinet will appear in you Model List (bottom left on the screen by default (i think))
2. You havent added any fitting links – I am not sure how will you connect all the panels. Are you working with CNC machine or are you planning to drill the holes manually?
3. Cutlist is included in .pdf but if you want to have it in excel (for exporting it later as .csv) I am including .txt file which you can import into excel ([Subscribe to Premium Support to view this media]
– in case you dont have access to tutorials on this site (use semicolumn as delimiter)
4. To make the front covering 2 or more units, you can: 1. construct a unit in 1 cabinet file that is looks like few units (Ness, please help with that, you made a video about it i think). 2. you can make a front of unit 1 overpass the side by the same amount as the width of unit 2. 3. You can add a 3rd unit that had only the front panel and is the size and shape of the fronts unit 1 and 2.
Unfortunately there is no inter-cabinet fitting links in PolyBoards at this moment
Cheers!
OfflineHi Evan,
Please just post the final version of your Polyboard file here and request your CabinetFile.
We’ll process it and upload the cut list and plans right here too on the forum for you to download and use.
Thanks, Stefan
Rafal, that worked perfectly thank you for such detailed instructions, my only remaining question as far as my model is concerned is if there is a way to join two cabinets together for a seamless front panel? I would like to combine the “desk” and “pos” units. If this is possible please advise how to do so.
also please point me in the right direction on where on the forum to submit my project to receive my build documents.
Thanks in advance!!!!
