Surface split keeps being overridden |Forum|WOOD DESIGNER
Matthew Murphy
Forum Posts: 41
June 29, 2022 - 1:52 pm
Excellent thanks again Alex, problem solved
Forum Posts: 2128
June 28, 2022 - 10:00 am
I understand!
When applying manufacturing methods, or sub-method material styles that are applied Structure if checked also
and if the material styles of your sub-methods have no structure, they will be deleted
Hope this video helpful
Matthew Murphy
Forum Posts: 41
June 28, 2022 - 8:10 am
ah it has not recorded the pop up sub menus, basically I selected the top did a surface split, then applied my manufacturing methods again which is when the top reverts back to a full piece
Matthew Murphy
Forum Posts: 41
June 28, 2022 - 8:08 am
I dont think i explained my self properly, i am sure there is a way to add it to a manufacturing method but i want this split pot piece to be applied when i apply the manufacturing method if possible, as when i check the cabinets and eg i fix a fitting conflict it overrides the top and i have to remember to go back and change it again.
I have uploaded a screen recording of what I mean.
thanks
Forum Posts: 2128
June 24, 2022 - 12:30 pm
I have never noticed any of these problems,
Please make caution to this, when your are in project mode, and open cabinet From project they where saved only in the current project
When you update cabinets outside of a project, it does not update the cabinets used in the projects, you must “add” them again.
Would it be possible to update Polyboard to 7.08C
information and download link here
https://wooddesigner.org/forum…..e-updates/
and if needed instruction here
https://wooddesigner.org/help-…..-software/
Can you upload your cabinet/project for analysis?
All the best, Alexandre
Matthew Murphy
Forum Posts: 41
June 24, 2022 - 7:45 am
Hi i am near the end of setting up our basic standards but i am having a problem with the surface split for the top of a lower unit. eI go from project mode to cabinet mode and put the surface split in the top panel. then when i save and go back to the cabinet it gets overridden, the same thing happens when i apply manufacturing methods. is there a way to make this surface split part of my manufacturing method so it is applied every time for a my lower units?surface-split-settings.jpgImage Enlarger
Guest(s) 37
brendan kavanagh: 227
Emmanuel Sacco: 196
Carl O'Meara
polyjohn
Maxime Marengere
everslyjoinery
Topics: 2906
Members: 540
