Your fitting is perfect! but the rules using are not adapted
to align the fitting, you should select
120/120/p to follow overpassing drawer bottom on Counter frontage
and
120/120/n to follow underpassing drawer bottom on Frontage.
to have the same reference panel
a panel covering another panel is considered as overpassing panel
now you understand this point you can create link between sides (overpassing) and drawer counter-frontage and back (underpassing)
(titus normally equals to minifix)
All the best, Alexandre
May 21, 2021
I fugred out, how to create drilling in fasade and counter-front, but could you please help me out - how I can create that 5mm drilling is at the same position in counter-front? I`m using the same rule, but centers are not at the same position.
Second question - how I can create rule for drawer side and front to be connected with minifix?
Thanks in advance.
