Texture orientation |Forum|WOOD DESIGNER
Texture orientation
September 19, 2024 - 3:21 pm
You can make 90°display rotation, from menu Tools > Preferences > Panels tabs
Display-ori.pngImage Enlarger
But you can’t switch them
Blaž Jašovec
Forum Posts: 20
September 19, 2024 - 3:09 pm
Thank you
The problem was that i had panels in opticut saved so that the widht of the panel was the lenght (2800mm) and not the hight like you shown
It is a bit awkward fore me because i use the hight=2070 an width= 2800mm
Is there an option to switch this two parameters ?
September 19, 2024 - 2:30 pm
Sorry for my english hope my explain is quite clear,
Blaž Jašovec
Forum Posts: 20
September 19, 2024 - 1:48 pm
Hello
I have a problem positioning the texture in polyboard and opticut
When the orientation is along the hight of the cabinet in polyboard  i get the wrong orientation in opticut. The part is orientated along the hight of the stock panel not along the lenght like it should be.
I have tried changing the orientation of the texture in the material library, but then i have to orientate the texture on the cabinet along the width of the cabinet not the hight witch is also not corect. This solves the problem in opticut.
Is there a way to fix this an so that it is orientated corectly?
Guest(s) 30
