Yes – when you have 2 panels that you want to connect like that, click on the underpassing one and in Properties > Links expand the one that you want to change the connection with, then change its’ type to Mortise & Tenon. You will see more parameters appearing in there, just play around until you’ll get what you want.
Best Regards,
Rafal
April 10, 2018 - 7:54 am
Somtimes there are no thin version of some panels so I must make grooved back of the cabinet with 19mm thick panel. Is there a way to make this kind of grooving?
