Lost password?
Thickness split
Forum Posts: 914
November 11, 2022 - 10:06 am
Hi Connor,
When you have done a thickness split and applied 2 different materials to it, you can save this as a structure in the structure library and apply it at all times when you needed on another element. You can also automate the process by creating an extra shelve and applying the structure via the materials style submethod in the tab structure.
using the copy-and-paste function also ad structures to panels. So there are different ways to do it faster
Conor Devoy
Forum Posts: 132
January 28, 2018
November 11, 2022 - 8:03 am
Good morning all,
I am making a cabinet with 44mm sections made up of a sandwich of 19mm oak plus 6mm mdf in the center and 19mm oak bonded together.
I have created a fake 44mm oak in libraries, drawn the cabinet and I am now using thickness split to change every shelf and upright individually.
Is there a better/faster way to achieve this.
Is it possible to create a multilayer material in libraries or do something in methods.
Regards and thanks,
Conor
Currently Online: Stefan, Hasse Svensson, jonathan P, Adrian Carelse, Muneer Binwabar, Jovanovic Nebojsa, lu ar, Franklin Ramirez, Roman Vasetski, VICTOR MALDONADO, HUY TRAN, gaurav verma, Kobus Thiart, Anil V, Nikola Kiric, Peter Sloan
Guest(s) 1
terry: 253
mark nichols: 157
Tom Cleaver: 144
Kerf Works: 143
Duayne Naugle: 124
brendan kavanagh: 112
jimbouk: 105
Syslab Corp: 103
Stu Robertson: 102
samuel Akapo
samuel Akapo
Marko Pedosk
mus til
kadri kadri
Vicky Hunter
ostojic filip
Michalina Bedyk
Conny Sii
Mª Antonia Barbero
Topics: 1827
Members: 150889
Administrators: Ness, Stefan, Michel, Carole, Alex, admin, Laly, ipatrick, Fatima, Crystal, Jem Turner, Darren
