This should be a very Quick Fix: Overlay Door/drawer zone Control|Forum|WOOD DESIGNER
Tom Jackson
Forum Posts: 136
October 17, 2024 - 2:16 pm
Mate, you’re a ledge thank you – that solves my problem! Yeah I plan to use Divario fittings for the vertical panel. The 3mm screws in the back of shelves, and Divarios for the shelf itself left and right.
Cheers,
Tom
October 17, 2024 - 11:25 am
Tom,
See the attached video.
Tom Jackson
Forum Posts: 136
October 17, 2024 - 10:37 am
Hi Alex,
I knew it would be a simple solution – thank you.
I do however wonder if its possible to achieve this result without have the vertical division going to the top. Can we create a ‘T’ shape with a shelf above and vertical division below and everything else as you had created?
Cheers,
Tom
October 17, 2024 - 7:58 am
Area/Zone selection is done in reversed order of adding components, with clicks repeated zone by zone
Maybe you can divide your fixed shelves on top in two?
Tom Jackson
Forum Posts: 136
October 16, 2024 - 3:20 pm
I’ve uploaded a cabinet for you to review please. My goal was to have a shelf 350mm from the top, then below a vertical division to split the cabinet 50-50.
The challenge I have, is one side of the vertical division will be x3 overlay drawers at 500mm Depth. How Can I have overlay drawers, an overlay door above that whilst selecting half of the shelf space above?
I hope my wish is clear. The client wants a shelf at the Top to Make the ‘T’ Shape. but it’s not considered a vertical zone where the door would be.
I feel like this will be easy for you.
Any help would be great.
Cheers,
Tom
  • sp_PlupMedia A.zip(293 KB)
Guest(s) 46
